Bruceb_uk_1
Oct 29, 2019Initiate
Ethernet switch to support multiple PCs on on workstation
I have the following home network: Cable ISP with an Orbi mesh network, plus power line from the Orbi basestation to support wired network devices like NAS box and TV Humax box. My workstation con...
- Oct 30, 2019Thanks Michael. I took the plunge and bought the switch (Netgear, obviously đ) and itâs currently handling the NAS traffic just fine.
Just a few more connections set up and test....
Thanks
Bruce
michaelkenward
Oct 30, 2019Guru - Experienced User
Bruceb_uk_1 wrote:
Can I add an Ethernet switch to manage the single available Ethernet connection (via Powerline) and distribute it to the NAS/NFC-storage/HP?
I have a single powerline plug going out to a router that feeds other LAN stuff with more than one device connected. I haven't tried it with a switch, but I can't see why it shouldn't work.
- Bruceb_uk_1Oct 30, 2019InitiateThanks Michael. I took the plunge and bought the switch (Netgear, obviously đ) and itâs currently handling the NAS traffic just fine.
Thanks
Bruce- michaelkenwardOct 31, 2019Guru - Experienced User
Thanks for the confirmation. Glad it works
The annoying thing about these issues is that had we all thought we would need those extra ports at the outset we could have bought plugs with two or more ports.
But we all underestimate how many devices we will want to bolt on to our networks. I have gradually moved from four-port LAN switches to eight ports and now 16. Fortunately, the price has steadily fallen.
