jimmy27
Feb 20, 2018Aspirant
FA311 Network adapter not seen by Windows 10
I have an FA311 v2 network adapter which I've installed on a Windows computer running Windows 10 Pro 64-bit. Windows does not see the card as being present in device manager. I'm not finding any softw...
jimmy27
Feb 21, 2018Aspirant
Michael, thank you for your reply. I realize this may not be the appropriate forum to start this thread but I did not find the forum you linked dedicated to wired networking so I picked one out of the hat. Looks like you did give me good help anyway. You correctly informed me I am using obsolete technology and that pretty much says it all. I installed a Intel PWLA8391GT PRO/1000 GT PCI Network Adapter and all is working fine. Looks like the best choice for my FA311 is to turn it in at my nearest computer recycling center. I get it. Thanks again for taking the time to read and post.
J.
michaelkenward
Feb 22, 2018Guru - Experienced User
That would have been my choice, given the cost of a new LAN card. The last one I bought even doubled as a USB3 hub.
