MPIC112
Mar 09, 2022Follower
Forgot wifi password for Powerline PLW1000v2
I had disconnected my powerline and decided to reuse it again. I cannot remember my wifi password and also need to change security settings
1 Reply
You can hardwire into it or access it using its ip address to get that info
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
