mulanee
Nov 03, 2019Tutor
Freebox + freeplugs and XAV5421 compatibility
Hi, New owner of a freebok and its freeplugs, I cannot manage my 2 CPL devices XAV5421 adapters properly. These adapters are causing a loss of connection on the freeplugs, nothing works anymore. H...
michaelkenward
Nov 04, 2019Guru - Experienced User
What's a CPL device? What are freeplugs?
If you are talking about running two Powerline networks, then you might fund it easier to create a single network.
Most modern plugs are AV standard and can work together. You need only one plug connected to the router. Then add the others in the usual way.
- mulaneeNov 04, 2019Tutor
Freebox is the name of the modem/router provider by the internet provider free.fr in France.
It supplies also 2 freeplugs which are power supply+cpl devices:
200 Mbit/s Ports 1x Ethernet 100 Mbps + power supply
HomePlug AV
- michaelkenwardNov 04, 2019Guru - Experienced User
What are these cpl devices? (Google is no help.) A pair of powerline plugs?
Freeplugs are provided by the internet provider in addition to the modem/router:
