bscloutier
May 17, 2022Aspirant
Frustration adding a PL1000 to a PL1200 pair
I have a successful pairing of PL1200 Powerline extenders. This is providing network connection between the house and the barn (where oddly there are some electronics). I bought a PL1000 pair thinkin...
May 17, 2022Guru - Experienced User
It could be a distance/single issue. Powerline devices aren't long range devices and crossing circuits attenuates the signal quite a bit.
The one might just be close enough to reach.
You can try setting them up all on the same circuit to see if they connect. If they do, its not a device issue but more likely a distance/interference issue.
