MRCJR
Feb 12, 2023Follower
Having 3 powerline adapters connected
hey, so i have been using 2 Powerline 2000 adapters for years without issue and have decided to add 1 more so i bought another set but as mentioned only need to add 1 at the moment. I've tried doing...
michaelkenward
Feb 13, 2023Guru - Experienced User
Is this what you did?
>>> Adding a powerline adapter to an existing powerline network <<<
You need just one plug wired into the router.
I find it easier to set up plugs alongside one another where it is easy to check that they are connecting, and then to move them to their final destination. They will remember their settings even when unplugged and moved.
