fast2406
Apr 28, 2012Novice
HDXB101 compatible with newer models?
I've got an older pair of HDXB101 powerline adapters and need an extra one. Unfortunately they have been discontinued, so I was wondering if I can buy one of the newer models? Would they work together...
fast2406
Apr 29, 2012Novice
I appreciate your reply - thank you. I couldn't find a HDXB101 on ebay so I was wondering if there is a list of 'older' versions that would be compatible? If I do a search for Netgear Powerline on ebay I find loads but unsure which one to pick ... any advice?
Cheers.
Cheers.
