ripewithdecay
Aug 26, 2011Aspirant
Help with XE102 and Belkin N150 Connection
I had been using a wireless DSL modem with the XE102 plugged into it for XBOX usage for quite awhile with no issues. Today i switched over to comcast and bought a Belkin N150 router. The internet w...
jmizoguchi
Aug 26, 2011Virtuoso
setup static IP on xbox out side the DHCP range of belkin router and see ( see belkin manual if you do not know where you will find DHCP settings)
