bayviewfox
May 22, 2024Follower
How many powerline 2000 can use same network?
- May 23, 2024
plemans wrote:
We usually tend to see issues after that 3rd node if they're going to have issues.
It may depend on the plugs, their model number. I have also see them doing OK until they hit the sixth plug.
How many are you needingA key question. And are they wired or wired/wifi?
May 23, 2024Guru - Experienced User
according to netgears official document, you can have up to 64.
Product FAQ: Powerline Adapters - NETGEAR Support
How many ar eyou needing
- michaelkenwardMay 23, 2024Guru - Experienced User
