marcos
Jul 24, 2014Novice
How set up security with XAVNB2001?
I've been using this system for about six months. Had a power failure, and when everything came back up the Netgear system would not work. Had to go through a factory reset and set up the whole thing ...
paulfrom34
Sep 07, 2014Aspirant
How do you set-up security say WPA2 for homeplus system - I do not use Netgear router - at the moment the Netgear Ext operates unsecured.
Thanks
Thanks
