jay2121
Jul 15, 2021Tutor
How to circuits work> powerline 2000
I have a house and about 200 ft is a second house. Do I need to go to the first house where the router is and find a circuit and plug into that? Then turn the breaker off and see what house two is...
Jul 15, 2021Guru - Experienced User
200ft and being on seperate circuits is probably what your issue is.
Powerline suffers from interference as well as distance.
If you could potentially get both powerline devices on one circuit it *might* make it that far.
You'd be better off either running an underground ethernet wire or using a point to point system to get a connection between the 2 homes.
jay2121
Jul 15, 2021Tutor
Whats point to point? My eletriction is going to swap the poles so put it on the other circuit.
- plemansJul 15, 2021Guru - Experienced User
a point to point system is just like it sounds.
Its a system designed to extender further than an omnidirectional wifi can reach.
so it can connect from 100ft to 9000ft (for some systems).
Its great when you're out of ethernet/coax/powerline range.
Again, your electrician can try swapping stuff around but 200ft is quite a ways for powerline.
Even if you do get them connecting, it might not provide much for throughput (speed)
