grcutter
May 30, 2012Aspirant
How to get Ethernet to my Pole Barn? Too far for XE102?
Hi, I would like to get ethernet service into my pole barn which is about 200 feet from my house. I bought a pair of XE102 which work in every outlet in the house but not in the outlets in the barn. ...
Scubbie
May 31, 2012Apprentice
A WiFi Extender or Access Point could be used instead. The issue hear is that with the extended distance, the signal would drop.
Take a look at the WN2000RPT or the WN2500RP:
http://www.netgear.co.uk/home/products/wireless-range-extenders/
Alternatively look at the WG602 WG604 or WN802T:
http://www.netgear.co.uk/home/products/switches-and-access-points/access-points/default.aspx
You could run these in series. Do read the manuals first so that you can see which would offer the best solution for yourself.
Personally though I would still go with what fordem suggested. Do make sure that you use External Cat 5e cable, rather than normal Cat 5e cable. I would also consider adding a Network Switch every 90m if the total length is going to be greater the 100m/320ft.
Ethernet cable support their stated speeds for a distance of up to 100m provided that there are no sharp bends. If burying the cable is unsuitable, consider running it overhead, but ensure that something else takes the strain.
