Ascanio1
Jan 02, 2010Aspirant
http://192.168.0.101
Hi everyone, My internet is working correctly but I cannot open the page: http://192.168.0.101 WHat should I do? Thanks in advance, Tommaso
Ascanio1
methuselah_ wrote: you must be using wgx102 and trying to access its UI, eh?
check your router's attached devices/dhcp table and look for the wgx102 (check its MAC address). Once you get the IP address, use it to access the UI of the powerline. ;)
Dear Methuselah.
Give me a day (I need to find out what these dhcp, UI, IP and MAC are) and I'll get back at you! :-) Thanks!
I think I know what the IP address is, but I better check because I am thinking of the internet address and I cannot imagine that you're asking me for this (I must be wrong)...
If the router is the appliance that receives the internet connection from the outside, I guess... right? If so it is a Buffalo Airstation Nifty Giga. It is not attached to anything. It receives a cable from outside. I know that it is a optic fibre high speed internet from NTT Docomo, I live in Japan.
Sorry for my ignorance and thank you for your time! I'll try to find out these items if I can't find them, is there any simpler way to explain what I should do?
Again, thank you for helping, ciao,
Tommaso
