Ascanio1
Jan 02, 2010Aspirant
http://192.168.0.101
Hi everyone, My internet is working correctly but I cannot open the page: http://192.168.0.101 WHat should I do? Thanks in advance, Tommaso
jmizoguchi
Jan 03, 2010Virtuoso
make sure that your buffalo and XE102 are configured correctly so that both devices IP is using 192.168.0.x if buffallo DHCP is other than 192.168.0.x then you will not able to reach 192.168.0.101 if LAN subnet is the same but you still can not access the interface then you may need to reset the XE102 device.
Ascanio1 wrote: I use a Sony Vaio SZ1VP with Win XP and Office 2007 and there is an appliance called Buffalo Airstation Nifty Giga under my desk into which a cable enters from outside and, from which, a cable goes into the Netgear Model XE102 appliance. Around the house there are other Netgear appliances, model WGX102, connected to the electric outlets. Tommaso
