Ascanio1
Jan 02, 2010Aspirant
http://192.168.0.101
Hi everyone, My internet is working correctly but I cannot open the page: http://192.168.0.101 WHat should I do? Thanks in advance, Tommaso
methuselah_
Jan 03, 2010Aspirant
he meant the WGX102. ;) right jmizoguchi? :cool: @Ascanio1: yes, just post your questions and network set up if possible. this illustration here. Please verify what IP address comes from your router is 192.168.0.x. If the third number is NOT zero, you would need to change the IP of the WGX102 to something in the same range as the router. Let us know first, then will give furhter instructions. You can PM as well if you want. :)
reset the XE102 device
