miki_js
Jul 31, 2024Follower
I have tried everything to connect to mywifiext net and it always says I'm not connected -PLW1000 v2
I have tried connecting via ethernet, connecting via wifi, two different browsers, moving the range extender to the same room almost right next to the router, and I tried logging into the range exten...
Jul 31, 2024Guru - Experienced User
to reset, push and hold reset for 7-15 seconds while its powered on. The lights on it should change when held long enough.
That'll get you back to factory to where you can reinstall it
