miki_js
Jul 31, 2024Follower
I have tried everything to connect to mywifiext net and it always says I'm not connected -PLW1000 v2
I have tried connecting via ethernet, connecting via wifi, two different browsers, moving the range extender to the same room almost right next to the router, and I tried logging into the range exten...
michaelkenward
Aug 01, 2024Guru - Experienced User
miki_js wrote:
Does factory resetting the extender do anything to this password, or does it literally just reboot the extender. I'm at a loss and need help ASAP.
It wipes out any settings and returns the device to its default settings.
This is essential if you have acquired a second hand device. You need to wipe out any old settings from the previous owner.
I assume that you have the "host" powerline plug wired to the router and that the "remote" plug (the AP one) shows a connection with its green LEDs.
Just another user with time on their hands.
