insanebe
May 02, 2012Tutor
ip address issues Netgear XAVB1501+ powerline & Netgear DG834PN router
Products = Netgear XAVB1501+ powerline & Netgear DG834PN router Problem When trying to connect either my xbox or pc using the powerline adapters i get the message "invalid ip address" or "failur...
insanebe
May 02, 2012Tutor
MUAHAHA i solved it :D
you must i repeat you MUST rename the powerline adapters using the powerline config utility otherwise the router wont give out any ip addresses
plug and play my ass :p
