david23
Apr 30, 2012Aspirant
Mixed devices on powerline ???
SORRY FOR THE VERY BASIC QUESTION: I have a HOME NETWORK NETGEAR POWERLINE XE102 and WIRELESS WALL PLUG RANGE EXTENDER with WEP security. I was thinking of adding another XE102 (or two) to the ring m...
jmizoguchi
May 19, 2012Virtuoso
http://support.netgear.com/app/answers/detail/a_id/1125
You find how many of same device can be installed ...
WEP are wireless portion therefore if you are not going to use wireless then disable it and use ethernet out of the power line device.
