FloresFFX
Sep 26, 2012Aspirant
Mixing powerline max Mbit/s adapters
Can I mix adapters of different max speeds? The "base" unit is a XAV5001 (max 500Mbit/s), the first room has a XAV5004 (max 500Mbit/s), I want to put the WNXR2000 (max 300Mbit/s) in the third room....
FloresFFX
Sep 27, 2012Aspirant
Thank you June for the prompt reply.
So if I understand correctly the WNR2000 actually has a lower powerline Mbps than I thought (only 100Mbps) the 300Mbps refers to the wifi connection. But will be maxed at 100 via this connection.
Thanks again.
Thanks again.
