CD_PLWP's avatar
CD_PLWP
Guide
Jan 29, 2022
Mywifiext access pb with default ID/PWD
Hi,
I bought a second hand PLP1000/PLW1000v2 kit and dit not manage to enter Netgear genie interface following official tutorials : i.e. launching Mywifiext adress and use "admin"/ "password" to log in.
Two advices  :
- directly access to IP adress of the PLW1000v2  (beware of any fixed DHCP IP )
- have a look at : https://kb.netgear.com/000061551/PLW1000v2-Firmware-Version-1-0-0-18   ==> Netgear has changed default password (but no information found elsewhere)  . Log in with  "admin" + default wifi key.
  • No more issue.
    I was just saying that , like many other people, I tried to log in with default ID/PWD : "admin" / "password" and did not succeed.
    The reason is Netgear has changed the default password with the last firmware.
    ==> If you keep on trying with "admin"/"password", you'll never log in.
     It's just an information I want to share
  • plemans's avatar
    I'm not sure what exactly you've got going on.
    Are you having problems loggin into the device?
    What are the led's on it doing?
    did you factory reset it?
    • CD_PLWP's avatar
      CD_PLWP
      Guide
      No more issue.
      • gdiaz's avatar
        gdiaz
        so what is it
        CD_PLWP wrote:
        No more issue.
        so what is it
