jim2007
Jul 09, 2019Aspirant
Need help to Boost Wifi and connect Hard wire device - Recommended product?
Hi I have really slow Wifi in my Bedroom (my Wifi router is in my Lounge not too far away) and looking to boost the Wifi so I can easily use my Laptop and Phone with no issues of slow or dropping...
Jul 09, 2019Guru - Experienced User
Couple things
1. What router are you using? firmware on it?
2. you state your bedroom isn't to far from the lounge. How far is "not to far"? It allows us to better determine if its an expected result for having slow wifi at that distance or if there's troubleshooting to be done for that aspect. What is the wall material in between? Concrete, brick, hvac, and foil lined insulation do a great job of blocking signals.
3. What wifi adapter is your laptop and phone using? Dual band/single band?
4.If you're looking for powerline with wifi built in, Netgear does have that option but it doesn't have a current version with wifi and powerline passthrough available. Passthrough is an option with the nonwifi powerline adapters.
jim2007
keeps giving me this error when trying to post my answers
Correct the highlighted errors and try again.
- There was an error while attempting to post your message. Try again in a few minutes.
