jim2007
Jul 09, 2019Aspirant
Need help to Boost Wifi and connect Hard wire device - Recommended product?
Hi I have really slow Wifi in my Bedroom (my Wifi router is in my Lounge not too far away) and looking to boost the Wifi so I can easily use my Laptop and Phone with no issues of slow or dropping...
michaelkenward
Jul 10, 2019Guru - Experienced User
jim2007 wrote:
I need to have through plugs aswell as ive only 1 available plug socket which goes into an extension cable then half way round my room to power my wall pounted tv and box etc
Is this in the place where you have the router, or where you want to extend the network?
Netgear advises against using extension cables with Powerline devices. My experience is that it doesn't matter.
One solution to the problem is to have simple Powerline plugs between the "source" and destination, and to put a wifi extender or access point at the remote end. You can then plug stuff into the LAN ports there and use its wifi for other things. I have an Orbi router in AP mode at the end of a Powerline network.
But like plemans I'd like to know more about your router and the layout of your network.
jim2007
Jul 10, 2019Aspirant
Ive a Hub 3.0 with the latest firmware
The extension cable is in my Bedroom where I want to extend my network.
Im not looking to spend too much (under £60 approx) and want an all in one solution to avoid different setups and confusion and something I can take with me if I move. Would a powerline with wifi capability just do the trick? as that seems it would serve all my needs. Only really need 1 hard wire connection also and to ensure wifi is good in my room for laptop or phone when i need.
I tried the VM Connect app and it did flag as a black spot and said it rectified it but a speedtest later on shows differently! lol
- plemansJul 10, 2019Guru - Experienced User
Hub 3.0 might be what its called but we'd need a model number and name to help.
I couldn't find any Netgear powerline adapters for the UK that have integrated wifi and passthrough. I did find some from other companies but most were >£60.
What wifi adapter are you using?
have you tried changing wifi channels to help with signal interference?
Or changing the router placement to see if that'll help with signal broadcast?
- jim2007Jul 10, 2019Aspirant
I would consider paying more for the right ones, that was just a rough idea of a budget. Ive seen some fantastic ones but they are £120 which is a bit steep if im being honest.
Ill need to find the details on the Hub when im in from work. What will the name and model help identify?
Thanks
Thanks
It'll help us determine how well the basic device should work. If your room is close to where the router is, it might be something you can try to get your wifi working better versus adding in a powerline device, extender, etc.
- michaelkenwardJul 10, 2019Guru - Experienced User
In the UK it is probably the Homehub 3.0, an ancient and not very capable modem/router from BT.
Unless this is a gigantic house, replacing it with a decent modem/router could beef up the wifi significantly.
Other brands will be cheaper. BT evens sells these things.
To my mind the passthrough is a red herring. Just by a three-way adapter for about £5 and use that.
I know its the Hub 3 from Virgin Media which I must have got about 18 months ago now
My house is pretty small, upstairs split house so all on the same level and 2 bedrooms
I didnt think about that and getting a better router that could increase my wifi coverage but would still have the need to hardwire my devide in my bedroom which is a big thing as its to ensure my IPTV/Netflix subscription runs lag and buffer free
Regarding the layout of my room, would it be useful to draw a diagram and upload the file here? visually might be easier, can also place where the router is
