jim2007
Jul 09, 2019Aspirant
Need help to Boost Wifi and connect Hard wire device - Recommended product?
Hi I have really slow Wifi in my Bedroom (my Wifi router is in my Lounge not too far away) and looking to boost the Wifi so I can easily use my Laptop and Phone with no issues of slow or dropping...
Jul 10, 2019Guru - Experienced User
Hub 3.0 might be what its called but we'd need a model number and name to help.
I couldn't find any Netgear powerline adapters for the UK that have integrated wifi and passthrough. I did find some from other companies but most were >£60.
What wifi adapter are you using?
have you tried changing wifi channels to help with signal interference?
Or changing the router placement to see if that'll help with signal broadcast?
michaelkenward
In the UK it is probably the Homehub 3.0, an ancient and not very capable modem/router from BT.
Unless this is a gigantic house, replacing it with a decent modem/router could beef up the wifi significantly.
Other brands will be cheaper. BT evens sells these things.
To my mind the passthrough is a red herring. Just by a three-way adapter for about £5 and use that.
- jim2007Jul 10, 2019Aspirant
I know its the Hub 3 from Virgin Media which I must have got about 18 months ago now
My house is pretty small, upstairs split house so all on the same level and 2 bedrooms
I didnt think about that and getting a better router that could increase my wifi coverage but would still have the need to hardwire my devide in my bedroom which is a big thing as its to ensure my IPTV/Netflix subscription runs lag and buffer free
Regarding the layout of my room, would it be useful to draw a diagram and upload the file here? visually might be easier, can also place where the router is
- michaelkenwardJul 10, 2019Guru - Experienced User
Any router should be able to fill that space with wifi. So it is probably worth looking for other reasons why things go wrong.
What is the wifi device that is slow in the bedroom?
Is it a lot faster when you are closer to the router?
How fast is your Internet service?
Have you tried moving the router to a better location in the main room?
Everytime i post specific information about my hardware etc it posts then deletes the post and says access denied.
I dont want to break any rules here but find it tough when i cant post what im using
Intel(R) Centrino(R) Advanced-N 6235 - thats my laptop wireless network adapter
Phone is Samsung S9, pretty new. Works everywhere apart from lags in bedroom and bathroom
