chaoscreater
Aug 08, 2021Aspirant
Netgear PLP2000 performance comparison to TP-Link PA9020P
Hi all,
I have a TP-Link PA9020P, which is a competitor to the Netgear PLP2000. My ISP connection is 100/20 and I get maxed out speeds when I'm connected to my router via ethernet.
When I'm connected via my TP-Link powerline from about 50m away, I get around 65~95 Mbps down and 16 Mbps up. On average, my download would be around 65~75 Mbps and only sometimes hitting above 85 Mbps. I don't really have an issue with my TP-Link, as it is pretty stable and performs quite well. However, the speed not ideal sometimes and so I'm looking to try out the Netgear.
I've read some articles and it seems that Netgear performs better, but I can't find any good performance benchmarks and I can't find proper comparison tests between the Netgear and the TP-Link. Just wondering if anyone can provide some input on this please?
Also, my TP-Link is a v1 and the latest version (for the same model) is currently at v4. My understanding is that v4 has a better and newer hardware and updated firmware (only dedicated to that version). Is the same true for the Netgear? I can't find any firmware updates or any changelogs for the Netgear, so I don't know how to properly compare the 2.
MIght it help a little? Tough to say as it'd requiring someone to have both sets to compare with. Its going to be a bit rare.
And I haven't seen a whole lot for details on Netgears adapters or even much for support. It seems like users have to use other companies utlities to update.
Any chance you have coax ran through your home? A set of Moca Adapters (ethernet over coax) might get you better performance than powerline.
- chaoscreaterAspirant
Nope, I don't have coax in my house.
The reason why I'm wanting to try out a different powerline adapter is because I used to have a D-Link (can't remember the model). It was supposedly (on paper) to be on par with my TP-Link, but it performed a lot worse. So I think the bottleneck here is definitely the powerline.
Regarding firmware update using other other companies' utilities, could you elaborate a bit more on that please? What tools are they using and how are they actually updating their powerline? I wasn't able to find any firmware available to download for the PLP2000 from Netgear's website, so how did others update without a firmware file?
Zyxel makes a powerline utility that works based off the chipset and not the make of the devices. I've used it before but not recently so not sure if it still works. You can do a quick google search.
Sadly, I haven't seen a big difference between powerline makes on actual performance as it tends to be the same chipsets used. Difference is only usually around that 10%. Not enough to invest in new prodcuts in my experience.
Any chance a mesh network like orbi might work at your place?
