Johannam
Jul 17, 2023Follower
netgear powerline 1000 problem connecting dlink camera
Hi! I have a powerline 1000 installed for the wifi in my garage, it works fine when I connect my andriod phone. At the moment Im trying to install a Dlink camera in the garage and the camera dem...
michaelkenward
Jul 17, 2023Guru - Experienced User
Which modem PL? Connect to what router? With which modem/ONT/gateway between that and the Internet?
At the moment Im trying to install a Dlink camera in the garage and the camera demands a password for the extended wifi.
If the Android phone works as expected, sounds like something to ask dLink about.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Powerline Networking - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
