Ableseth
Dec 19, 2019Follower
Netgear Powerline AV500 + AV200 Does not provide connection anymore.
Hello! So, I've been using a Netgear AV500 network adaptor to link my computer to the router for awhile. Since the AV200 is compatable, I used that and connected that half to the router, and the A...
michaelkenward
Dec 27, 2019Guru - Experienced User
Not sure that I understand what is going on. Lots of confusing details.
Does everything work without using the Powerline plugs?
Ableseth wrote:
However, with a proper link secured, proper connection displayed and everything, all computers connected through the Adaptors show as Unidentifiable and have no internet access.
Where are you seeing these messages? Something in Windows?
My first guess, based on my poor understanding of your description, is that you need to tell Windows that you are on a "private network".
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
