beachmonk
Apr 28, 2020Follower
New User PLW1000v2
PLW1000v2 Firmware up to date Windows OS 8 connected with extender and cable Home Enviro with walls and books between router and laptop Cox Panoramic Router/Modem SORRY, if this has been cove...
Apr 28, 2020Guru - Experienced User
powerline devices are sensitive to interference. If your pick a plug light is red, it means you have the worst connection.
Amber is -decent and green is best connection.
things that can influence powerline is: surge protectors, gfci outlets, arc fault breakers, high draw appliances, bad/cheap cell phone chargers, old wiring, and electronics poorly designed that are feeding back into the wiring system.
You can optimize powerline device. here's an article with a few tips.
