samjones4's avatar
samjones4
new XE104: Worked for 10 mins, not any more...
Wellllll, what to do?
Bought brand new XE104
Plugged one in one room, to router and wall.
Plugged the other in the next room (the remote)
The remote went solid blue for awhile,,, but no more.
Seems like they can't talk to each other.
I gotta do the plug around the house dance?
Annnnd, if it wont work in the room I need it to work in.... I send it back?
  • >> first test is to use within the same room, make sure it works
    Done!
    Works!
    Next?
  • various issue are usually some line noise in that circuit that you are connecting at remote end
  • >> various issue are usually some line noise in that circuit that you are connecting at remote end
    Thanks!
    Not a lot I can do about that...
    I'll have to send it back and do something else.
