Dalepenkala
Apr 06, 2023Aspirant
NG Powerline 1200
Hello, I'm kinda at a loss here with my Powerline 1200 adapters. I have had 4 of them connected and working just fine up until about 1-2 weeks ago. I have an observatory where I control 2 imaging r...
michaelkenward
Apr 07, 2023Guru - Experienced User
Dalepenkala wrote:
I have 2 powerline's in the observatory (which is about 180ft from the house)
That is heck of a run for Powerline. I am surprised that you got it to work over that distance.
I would also expect a mains circuit in a separate building to have its own fuse box and/or isolation switch. That is a big barrier to Powerline.
This bit isn't clear to me:
I have all 3 led's green, yet my laptops will not connect to the powerline. I have done a reset and they all connect in the house but when I have them back out in the observatory they do not want to connect any more.
What is the "they" you refer to here? The plugs or the laptops?
Dalepenkala
Apr 07, 2023Aspirant
Hello Michael,
Ya I was skeptical when I 1st set this up but I was very surprised that it worked as well as it did for me. Like I said it worked right up to about 1-2 weeks ago. I’ve tried to think back to see if I could think of something that could have caused a change but I just can’t think of anything.
As for the 3 lights, I’m referring to the 3 on the power lines themselves, not the laptops. I have 2 power lines in a dedicated electrical/receptacle box that connects right to the 100amp sub panel in my pole barn that is about 60ft away. Then that box is about 160-180ft from my main box to the house.
I would normally get the rigs up and running with all the software guiding the mounts. The laptops are plugged into the power lines and in the past they just flat out connected perfectly. When I walked back to the house I would just connect to the laptops via my PC that is dedicated for that link and connect with Google pc connect. Just worked like a charm. All of a sudden it doesn’t know.
Do you have a better solution for me if you think this is a stretch for the power lines?
Dale
- michaelkenwardApr 07, 2023Guru - Experienced User
I wasn't really asking about the "three lights".
What is "they" in this context?
- DalepenkalaApr 07, 2023Aspirant
They as in the computers will not connect to the POWERLINE’s an more even though all 3 lights on them are showing green.
Dale
The laptops.That is what I thought.
Unfortunately "will not connect" doesn't tell us much.
What happens when you try to connect? Error messages?
Windows PCs are good at protecting you from nasties. They can do this by blocking access to a new network connection.
You could troubleshoot the laptops as well as the plugs.
