bojac99
Dec 26, 2010Follower
Nook Color Won't Connect
I just got the Nook Color for Christmas and cannot connect to the WiFi in my home, although all four laptops connect with no issues. I went on the B&N website and found a blog stating the product doe...
pommom07
Dec 30, 2010Aspirant
I am having the same problem with my NookColor. My security is set to WPA2 and I have a RangeMax WPN842v3. It is so frustrating since the nook works everywhere but my home. Did you call the store or the customer help line. Also check to make sure you have version 1.0.1 on your nook. If I find a fix I will let you know.:confused:
