bojac99
Dec 26, 2010Follower
Nook Color Won't Connect
I just got the Nook Color for Christmas and cannot connect to the WiFi in my home, although all four laptops connect with no issues. I went on the B&N website and found a blog stating the product doe...
jmizoguchi
Dec 30, 2010Virtuoso
Use B&G mode in the router and see for wpn824 router
Seen these device may work with Mac address (access list) in the router but also can cause other device to fail connect for other wifi device. This one those you loose some to gain some . Some wifi device may not like Mac address either
