bojac99
Dec 26, 2010Follower
Nook Color Won't Connect
I just got the Nook Color for Christmas and cannot connect to the WiFi in my home, although all four laptops connect with no issues. I went on the B&N website and found a blog stating the product doe...
javacafe
Mar 14, 2011Aspirant
ShaneTheGreat wrote: Nook will works only in unsecured network, and always use 54mbps or b&g mode disable the mac filitering on the router
In correct! I have used my NOOK (not color) in a secured WiFi connections for several months. When you try to connect to a secured network, it even prompts for a passkey.
Recently, I had to reset my router settings because a few laptops and the NOOK were not connecting. Started happening only a few days ago. After the reset, the laptops are all connecting. The NOOK is also connecting to the router (I can see the Wi-Fi icon animating), but there is still an error message saying "Network Unavailable."
