guzzifrank
Jun 19, 2014Aspirant
One SSID across multiple access points
I have a larger home with multiple areas with dead wireless zones. I want to use the powerline products to basically flood the total area but with one SSIS and passphrase. Ideally I want to be able to...
fordem
Jun 21, 2014Mentor
Properly setup - single SSID, single encryption key, single DHCP server and your WiFi channels selected for minimal interference, you be as close to seamless roaming as you can get without a wiFi controlled installation.
You may experience momentary disconnections - for example - if you were in a Skype video call on a tablet whilst walking, you might lose the call, but the tablet will reconnect and you would simply need to call back .
