Dean_T
Mar 27, 2020Aspirant
Pick A Plug on Powerline 1200 is green, then red when connected
When I connect my Powerline Adapter 1200 to the router and wall and whatnot, the "Pick A Plug" feature turns a steady green. However, when I connect my PC (Windows 10), it turns to red. I have used t...
- Mar 28, 2020
Problem with powerline devices is that they're sensitive to interference. Things like cell phone chargers, surge protectors, arc fault circuits, gfci outlets, high draw appliances, old/bad wiring, or even just electronics that are going bad can all create interference.
Have you tried the powerline devices both in the same room on the same circuit? If they connect that router, then its probably something within the home that's injecting interference in the power system.
Like I said, random things can do this and if you've recently moved, it could be something within the wiring causing the issue.
Mar 28, 2020Guru - Experienced User
