Jaldea
Jul 10, 2020Aspirant
PL1000 1Gbps not reaching over 100mbps
I recently got new internet provider and with it a new modem and Glasfiber 1giganet network in my building, now im working 1 room away from the place where the modem is and the main PL1000 but i dont...
NoobZik
Jul 18, 2020Aspirant
Well, I have the exact same issue, I can't reach a speed above 100mb.
I have tried to disable the sleep mode but it doesn't helped at all. So if you have any suggestions, we will be happy to test it
Resetting did not work either
- michaelkenwardJul 18, 2020Guru - Experienced User
What device is this?
Remember, the LAN ports may be rated at 1000 Mbps, but you won't get that speed.
