philguk99
Jul 13, 2024Aspirant
PL1000 slow speed despite green PickAPlug led
Lots of discussion about my problem, but no definitive "solution" it seems With a wired or wifi connection to my router I can get a relaible 100Mbps on Speedtest.net I have one PL1000 wired straigh...
- Jul 16, 2024
Update (with a smiley face!)
I moved my PL1000s around. They’re still separated by quite a few feet (in separate buildings in fact) but I do know their on the same mains circuit
The PowerLine utility shows over 200Mbps link speed, but more importantly I get my ISPs 100Mbps on Speedtest.net
So, how the PowerLine network is constructed across your house wiring IS quire critical. My initial test, was with them on two circuits from the same consumer unit (breaker box), but presumeably split by mcbs!
Jul 15, 2024Guru - Experienced User
Powerline adapters are great because they tend to be pretty close to ethernet in terms of stability and consistent speed. But their speed isn't. Their speeds are over rated and tend to be sensitive to things like that power adapter. And even though the outlets might be close to each other, they could be on a different circuit. Smallnetbuilder tested the PL1200 and others of that generation and found on the same plug, they hit over 350mbps but move them to a separate circuit and it dropped below 100mpbs.
https://www.smallnetbuilder.com/lanwan/lanwan-reviews/netgear-pl1200-powerline-1200-reviewed/
You're getting even less than that. But you're also plugged into a power strip.
A couple questions. Are you testing with megabits/second or megabyptes/second?
https://www.jetspot.in/understand-your-internet-speeds-megabits-vs-megabytes/
Did you test the speeds on the same circuit to give a baseline?
- philguk99Jul 15, 2024Aspirant
Small steps
I took the power strip out of the puzzle, and now get just under 40Mbps (bits not bytes) - as measured at Speedtest.net
The two are still on separate circuits though. More testing tomorrow methinks
The house has just been completely rewired, so I’m 100% happy about that aspect
- philguk99Jul 16, 2024Aspirant
