Gerd12
Mar 21, 2019Follower
PL1200 Connectivity
I have been using the PL1200 with no issues for a couple months. This morning, my connectivity was gone. I have 'green' Power and Ethernet LED, however, the Pick A Plug is off (it worked fine as of l...
Jake1234
Sep 16, 2019Aspirant
I've had 6 PL1200's in service for many months and then all of a sudden they all stopped communcating with each other. The factory reset function will not correct the situation. This appears to be similar to Gerd12's issue, but I can't find the solution. Does anyone know how to correct this?
Jake1234
So I discovered the problem. One of the units was preventing the other 5 from communicating. Not sure, how, or why, but the 6 unit was the culprit. I removed it and the other 5 are now communicating fine. Will wait to plug in the 6th for the time being, but will reinsert tomorrow to see what happens.
