Hisco
Sep 07, 2022Follower
PLP 2000 how to connect a SMART RG router to the PLP 2000 as an extended wifi point.
Recently purchased powerline 2000 kit and would like to extend my network with an other router. How do I accomplish this?
1 Reply
It is usually a bad idea to add "another router" to a network that already has one.
What is Double NAT? | Answer | NETGEAR Support
Instead you could use the PLP2000 as a Ethernet connection to add an extender in wireless access point (AP) mode. You plug the AP into the Powerline plug. That's a better way of extending a network than using a wifi repeater.
While most routers do support AP mode, unless you have a spare lying around that you can use that is a bit of a waste.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
Instead, there are various purpose built extenders that you could consider. The choice depends on the router you own already.
