ColinTW
Mar 22, 2020Aspirant
PLp100-100UKS to talktalk powerlines (Dlink)
How can I add 2 PLP1000-100UKS to my existing powerline network, which I have. Which is Talktalk dlink powerline connections. I now need to have at least 3 powerlines on my network with home working!...
Mar 22, 2020Guru - Experienced User
which talktalk dlink adapters do you have? and actual model number. I'm not sure of dlink talktalk devices compatibility.
As well as if you want the talktalk devices being primary, then you need to check the with dlink how to add adapters (provided they're compatible) to their setup.
something to keep in mind with powerline devices is that they'll operate at the lowest devices speeds.
