Dazman9
Jun 01, 2021Follower
PLP1000 Compatibility with PLW1010 (or other wireless model)
Hey there, I live in an old house with thick brick walls where I stuggle to get a wifi signal in rooms more than one room away from the wifi box. I have a few PLP1000 ethernet adapters which work jus...
- Jun 02, 2021
As plemans says, it will work. But things to bear in mind:
- you can't buy the wifi (AP) bit on its own from Netgear, only the two-plug bundle
- Powerline is an industry standard, so you could add a different brand of AP plug to your existing network
- if you do buy the bundle, you need just one plug connected to the router
Remember, when adding new plugs to an existing network, you need to follow this advice:
>>> Adding a powerline adapter to an existing powerline network <<<
Another way to achieve what you want is not to buy the two-plug bundle with AP combined but to use a standard remote plug as the wired connection to a standard extender/access point. In this way you could get a remote wifi source that is more powerful than the bundled plug. I have an Orbi router (in AP mode) at the "remote" end of a Powerline network.
michaelkenward
Jun 02, 2021Guru - Experienced User
