jeffsmith82
Nov 05, 2020Aspirant
PLP1000 mixed lights
I have 3 PLP1000 powerline adapters connected and they all seem to have different coloured lights. In my loft room where my main socket for Internet is located has a plug that has a green light. T...
jeffsmith82
I understand the light means differnt speeds but what im asking is how do they work it out as mine is red but I get 70Mbps across it which seems to be wrong.
Also Im assuming with two adapaters its just the speeds between the 2 that determines the colour but i have 3 how does it calculate it then ?
If i have 3 adapters and one is in a bad socket does it turn the other 2 red and will it decrease their speeds ? Can i get better performance by removing it ?
Nov 05, 2020Guru - Experienced User
jeffsmith82 wrote:I understand the light means differnt speeds but what im asking is how do they work it out as mine is red but I get 70Mbps across it which seems to be wrong.---Red just means its detecting a bad connection. the connection strength can change but its saying its not the best. It could do full 70mbps and then later only pull 20mbps.
Also Im assuming with two adapaters its just the speeds between the 2 that determines the colour but i have 3 how does it calculate it then ?---not sure exactly.
If i have 3 adapters and one is in a bad socket does it turn the other 2 red and will it decrease their speeds ? Can i get better performance by removing it ?---try it. disconnect one and see if the problem goes away. mabye there's interference on 1 and its causing the issues with others.
