gavcav
Dec 16, 2021Follower
PLP1000 with Virgin Media, constantly disconnecting ethernet connection
I have 3 plp1000's used to connect a SMART TV and 2 Desktop PC's to the internet via ethernet. They have been working faultlessly up until a few weeks ago. Since then they have been causing problems...
Dec 16, 2021Guru - Experienced User
michaelkenward knows what they're doing with powerline.
And more than likely right. Its doubtful that the hub is causing the issue.
Its more likely related to something in your powerline system thats injecting interference.
things that can cause issues:
surge protectors
gfci outlets
arc fault outlets
electronics going bad
cheap cell phone chargers
old/bad wiring
high draw appliances
Basically if it was working fine before and it works fine at other people places, I'd be looking at what devices you have plugged into your network.
