DMJaxun
Jun 19, 2020Aspirant
PLP1000s wont connect with eachother
Today, I woke up to find that my PLP1000s had somehow disconnected from each other overnight (they had been working about 12 hours before). I have resetted and attempted to reestablish the connection...
- Jun 19, 2020
Me and my brother have swapped our receivers and it is now working, thanks for your help.
Jun 19, 2020Guru - Experienced User
have you tried them on the same electrical circuit in the house?
Many things add interference for powerline.
these can be:
surge protectors
gfci outlets
arc fault outlets
cheap/bad electronics
cell phone chargers (some)
high draw appliances
old/poor wiring
distance
So many things influence powerline. Trying them on the same electrical circuit reduces the interference
- DMJaxunJun 19, 2020Aspirant
Being as I am only 16, I am unfamiliar with the electric circuits in my house, all I can say is that they were on two different floors. My brother also is using a PLP1000 and his is working without any issues over the same circuit, we have both used our powerlines without a problem for well over 3/4s of a year.
- plemansJun 19, 2020Guru - Experienced User
Did you add them to his powerline setup or try to set them up seperate?
https://kb.netgear.com/22165/Adding-a-powerline-adapter-to-an-existing-powerline-network
We've had them seperate with no issues, he turns his receiver powerline off at night where mine decided to disconnect.
