BlackBufffaloJJ
Apr 02, 2026Aspirant
PLP2000 - no reset and button doesn't work
Good Morning, I have attempted to reset this thing via button push 8 to 10 seconds and also tried using the nighthawk app. None of this works, this has to be the worse product setup possible. ...
Apr 03, 2026Guru - Experienced User
What are you expecting it to do? the PLP2000 is a powerline only device. It doesn't do much.
What are the led's doing? Color? Blinking?
Hows it connected?
Are you going across circuits?
Tried in the same home?
Not a whole lot of data to go off based on your post.
