bob4bowling
Sep 03, 2020Aspirant
PLP2000 - one has three lights, other only two
I recently purchased a PLP2000 powerline kit. The devices pair correctly (both devices have pairing lights on and green). My hope is to be able to powerline output into a room in the back of the ...
michaelkenward
Sep 05, 2020Guru - Experienced User
bob4bowling wrote:
Right now, Device B is plugged into the wall at an outlet adjacent to Device A (same room, same circuit) with an ethernet output to the router. Device B has the ethernet light off (only two lights on in total), so it appears not to be receiving data.
The Ethernet LED will not come on if you do not have anything plugged into the Ethernet port.
Look at the bit in the manual LED Descriptions.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
- bob4bowlingSep 06, 2020Aspirant
Thanks, those manuals don't answer my question though. As I wrote, I do have something plugged into the ethernet on the Device B (output), it's the Nighthawk router.
On a whim I tried swapping the two devices so that Device B (with the two lights) connected to the modem-router and Device A was outputting to the new, second router. Device B is still only showing the two lights, (and Device A has three!) so I'm left to assume the equipment is faulty. Alas.
Thank you for the thoughts.- michaelkenwardSep 06, 2020Guru - Experienced User
Your description was not at all clear to me. As I read it, you seem to have both plugs connected to routers.
Diagrams always help,
- R_SeattleSep 21, 2020Aspirant
I have the exact same issue trying to get my powerline up and running so I could connect my Nighthawk AC3200. So I moved the second unit to the same room same circuit as the first. The one plugged into the xfinity modem has 3 greens - the second one has 2 greens and is missing the ethernet light so my assumption is that it is not receiving data. This is confirmed by any device I ethernet into it. When I contacted NetGear support, their solution was to continually factory reset the devices - which I already had done but did anyway. When that didn't work, their solution was to email me the user manual - which I had already downloaded. What do I do? There are only a few steps and none of them are working.
