MURRAY55
May 21, 2019Aspirant
PLP2000 - Two connections per side?
https://www.ca.netgear.com/home/products/networking/powerline/PLP2000.aspx
I cannot find this information on Netgear's website or Google for the life of me.
The PLP2000 shows 2 ether...
- May 21, 2019
One.
MURRAY55
Thanks!
So then (for instance) on the downstairs powerline, I could plug the router and also a separate device into it? I only ask because i'm running out of available ethernet ports on my router. I would assume yes but I'm just double checking ..
May 21, 2019Guru - Experienced User
Never tried it but you should be able to do so.
In regards to the running out of ports, you can snag a cheap 8 port gigabit switch for $15-20 usually
