eRomLige
Jun 18, 2022Aspirant
PLP2000 Ethernet LED solid red
What does a solid red ethernet LED mean? I currently have 3 PLP2000's that up to today have been working flawlessly for months. I wake up today and noticed all three are now giving me a solid red eth...
- Jun 18, 2022
Actually, I have 4 PLP2000's:
Router ---⫸ PLP2000 ------- PLP2000 ----⫸ WiFi router #1
| ---- PLP2000 ----⫸ WiFi router #2
| ---- PLP2000 ----⫸ Computer
So, the fix for me was to unplug all the PLP2000's, then plug them back in after about a minute, starting with the one closest to the router.
Everybody seems happy again.
Cheers
eRomLige
Cheers
michaelkenward
Jun 21, 2022Guru - Experienced User
From time to time, plugs seem to get lost. No connection to the router.
Usually it is just a case of rebooting the "host" plug, the one connected to the router.
First just unplug the Ethernet connection and plug it back in. If that doesn't work, turn the plug's mains on and off.
With luck the rest of the Powerline network will reconnect.
