gk65
Aug 13, 2018Follower
PLP2000 no Pick a Plug light
Bought a pair of these Powerline 2000 units to extend service into a bedroom/den where WiFi signal is weak. Set them up plugged directly into outlets, got Power and Ethernet lights (Modem and PC) but...
Aug 14, 2018Guru - Experienced User
You'll find documention for your PLP2000 here: https://www.netgear.com/support/product/plp2000.aspx#docs
Page 10-11 of the user manual describes how to reset the encryption key. http://www.downloads.netgear.com/files/GDC/PLP2000/PLP2000_UM_EN.pdf
