clarion
Apr 08, 2022Follower
PLP2000 Pick A Plug goes amber when adding the 5th unit
Hello community. I have acquired the 5th and 6th PLP2000 Powerline trying to extend my network.
When I add the fifth device and I join the secured network as described in the instructions, all my devices pick a plug turn into red (no amber).
I tried to reset all from fabric and recreate the network, but no matter how I join, the pick a plug turns red at the fifth.
Removing the fifth doesn't revert all the others into green, so I assume there is not a bandwidth problem.
Any thoughts?
Also I have seen there is a password in the back of every device. Is it possible to manually configure? How do you access that device mgmt interface? Ethernet? which IP address?
1 Reply
Have you tried removing one of the other plugs from the network while you add the 5th plug?
What about plug 6?
I have seen earlier conversations suggesting that Powerline falls over with six plugs.
